Author Topic: Fuel pump issue. PLEASE HELP!  (Read 4881 times)
Offline jdusten
« on: December 10, 2016, 07:29:08 pm »
I recently replaced the fuel pump, distributor, coil, plugs, and wires on my 87 chevy v10 (350 tbi with turbo 350 trans) after said work was done. The truck wont start. The battery was dead (truck had sat for a month or 2 since I parked it and slowly started working on it) so I put a battery charger to it and noticed the fuel pump would come on when the key is off, but turns off when the key is on. I've also come to notice that the pump doesn't always come on when the key is off, just intermittently.
So the problem comes down to-
Fuel pump randomly turning on when the key is off
Never coming on when the key is on
Any help will be greatly apprecated, thanks!
Re: Fuel pump issue. PLEASE HELP!
« Reply #1 on: December 10, 2016, 07:30:27 pm »
Sounds like the pump has bad/wrong wiring to it...
squarebody.biz
Offline jdusten
« Reply #2 on: December 10, 2016, 07:36:54 pm »
Thats what I guessed. But don't know where to start as the only wiring that I touched was the plug for the pump and the ground that bolted to the frame. What do you recommend trying?
Offline hatzie
« Reply #3 on: December 10, 2016, 08:41:33 pm »
Download the 1987 Fuel and Emissions book from the service manuals link in my signature. You'll find the following wiring diagram in the bottom half of PDF page 123
The ECM drives the fuel pump relay for 2 seconds when the ignition is switched to RUN and continuously when the key is turned to START.
Once the Oil pressure comes up to 4PSI the Oil Pressure Switch, this is not the gauge sender, supplies power to the fuel pump circuit as well.  It's a backup for the fuel pump relay.  I believe this switch is on the block near the oil filter.
If you have dual tanks the TAN/WHITE wire feeds juice to the tank switch to select the LH or RH fuel pump rather than directly powering the fuel pump.
The Fuel Module is usually only used on the 7.4L 454 but the service manual claims it was sometimes used on the 20 & 30 series trucks with the 5.7L 350.  This is sometimes called the Hot Fuel Module.  It's supposed to power the fuel pump for 20 seconds when the ignition is switched on.  This is on IGNITION power.
The ECM B fuse is on direct battery power not switched.  If the fuel pump relay or the Oil Pressure Switch are malfunctioning the fuel pump could run with the ignition switched off.  .
First.  Put a good charge on the battery with the Ground unplugged.  The ECM doesn't like low voltage and it may be malfunctioning because it doesn't have enough juice.
Unplug the fuel pump relay when the pump is running with the ignition OFF.  If it shuts off replace the relay.  If it stays on unplug the oil pressure switch.  If that fixes it replace the switch.
« Last Edit: December 10, 2016, 09:03:56 pm by hatzie »
