Author Topic: Rear Locker or Limited Slip?  (Read 6307 times)
Offline Dcraine101
« on: December 18, 2016, 06:22:16 pm »
What's up guys I recently bought a 83 c10 and I'm trying to figure out if it has posi. But I jacked up the rear end and it's weird. If I spin the passenger tire slowly the driver side spins in the same direction but if I spin it fast the opposite tire doesn't spin! And sometimes it'll even spin the opposite direction! So I don't know if it's an open diff or not! Any help would be appreciated! But no matter what if I spin it slowly forward they both spin in the same direction
Re: Rear Locker or Limited Slip?
« Reply #1 on: December 18, 2016, 07:32:20 pm »
Pull the cover and inspect, probably needs new gear oil anyway.
Have someone hold the other side.
Offline 87max
« Reply #2 on: December 19, 2016, 08:13:01 am »
what capt said, its probably open but just jack up one side if its a locker it will engage and you won't be able to spin it. if its a slip you will hear it try to engage. factory slips (some aftermarket) require wheel speed to engage the clutches you will not be able to do that by hand.
88 R30 lb7 transplant in progress
04 E350 6.0 studded & tuned work van
98 Taurus beater
