Author Topic: 1976 no tach cluster circuit board  (Read 3797 times)
Offline kcwis
« on: December 27, 2016, 03:25:32 pm »
Any recommendations on where to get a circuit board?
Offline 75gmck25
Re: 1976 no tach cluster circuit board
« Reply #1 on: December 29, 2016, 12:08:59 pm »
They are relatively expensive.
What is wrong with the circuit board you have?  If you are trying to fix overall issues with the cluster, I suggest you first re-check all grounds, especially the instrument panel ground under the dash, and verify  that the large wiring connector is mating properly to the cluster.
Bruce
« Last Edit: December 29, 2016, 12:38:04 pm by bd »
Offline hatzie
« Reply #2 on: December 29, 2016, 04:40:35 pm »
Wilcox Corvette but they are priced pretty dear.
Sent from my SM-P605V using Tapatalk
