Author Topic: Firewall tar?  (Read 5401 times)
Offline gearhead
Firewall tar?
« on: November 22, 2006, 08:23:00 pm »
I cleaned off the tar or sealer on the firewall so I could get at all the rust. Now that I have it primed, I was thinking of reapplying some sealer before I get into the colour coat.
Is there a brush on sealer I can use? I was thinking of a brush on an acrylic(? water based?)  paste we use on HVAC ductwork. It stays slightly pliable and spreads on easily.
I thought a bead of seam sealer would look out of place. (and it cant cover up all the rust pitting.)
Thanks in advance.
Re: Firewall tar?
« Reply #1 on: November 22, 2006, 10:25:00 pm »
I have used the stuff for HVAC duct work before. It worked OK. I usually use Dynatron gray of #3M gray brushable seam sealer with an acid brush or my finger. You can smooth it up with a rag and laquer thinner.
Offline kirkstheman
Re: Firewall tar?
« Reply #2 on: December 15, 2006, 02:05:00 am »
I know this is a late reply, but I bought some spray on rubber sealant from walmart. 3.97 and comes in a red and black can. In the auto department, by the spray paint section. Works great, prevents further rusting, and acts as a sound deadner. Works for the undercarriage also.
