Author Topic: 1986 Silverado 2wd differential  (Read 3916 times)
Offline cisco8604
« on: January 02, 2017, 10:55:15 pm »
My truck has a new motor and rebuilt transmission but it's not moving replaced transmission with a new one still no movement both transmissions go in to gear . They only work in high rpm. I replaced governor gear, module, flushed lines , changed filters, I have a new vacuum line hooked up new coolant lines. I took off the differential cover no metal shavings. I put my truck on blocks dropped drive shaft transmission changes gears fine I put the shaft back on  no movement. Drive shaft does have about 3-4 inches of play maybe to short
Sent from my iPhone using Tapatalk Pro
Re: 1986 Silverado 2wd differential
« Reply #1 on: January 08, 2017, 02:44:27 pm »
so with everything connected the truck won't move at all?
Is the driveshaft yoke engaged into the trans?
Offline cisco8604
« Reply #2 on: January 11, 2017, 07:29:02 pm »
Definitely sure
Offline cisco8604
« Reply #3 on: January 11, 2017, 07:29:53 pm »
Got no movement  still
« Reply #4 on: January 18, 2017, 01:15:18 pm »
Is the rear axle locked up?  This is a 2WD truck, right?
squarebody.biz
