Author Topic: Interior turn signal bulb  (Read 4506 times)
Offline Tazman
« on: January 07, 2017, 09:16:48 pm »
After getting my gauges back together I noticed my left turn signal was out. Thinking it was an exterior I checked and they are fine. So I pulled the dash front off and the clear then black covers. The bulb is in a tight spot, took needle nose to get it out. Checked the bulb with a couple connections and the bulb is fine, so that leaves the socket as the culprit. Does that involve taking the gauge cluster completely out?
Thanks
God BLESS AMERICA
Offline hatzie
Re: Interior turn signal bulb
« Reply #1 on: January 07, 2017, 10:50:47 pm »
Once you have it stripped that far down it's only three more screw fasteners, the cluster plug, and a spring clip to the speedo cable.  Be careful of the mounting tabs they get brittle with age.
The lamp sockets come out with 1/4 turn.
Take a soft paper-mate pink pearl pencil eraser and lightly rub the contacts on the cluster plug and the lamp socket terminals, if they look too dark, to remove corrosion.  Don't rub the printed circuit you'll de-laminate the copper from the plastic.
Spray the plug and lamp socket with Caig Deoxit D5 and wipe em dry.
Don't hose the contacts on the printed circuit with Deoxit D5 it might not play well with the plastic.  You may be able to use Deoxit D5 on them but you shouldn't just spray it on.  Spray some on a cloth and wipe a tiny amount of it on the printed circuit somewhere non critical to check whether it makes the plastic do nasty things.  If it seems safe use a Q-tip with Deoxit D5 to clean the copper contacts on the plastic and wipe it off ASAP.
You can plug the cluster in without putting it all the way back in the dash to test it.
« Last Edit: January 07, 2017, 10:52:36 pm by hatzie »
Offline Tommyd11730
« Reply #2 on: January 18, 2017, 11:30:57 am »
On my turn sig indicators the printed circuit was going south.  Couple surface mount jumper leads soldered on and it's good as gold.
1991 K5
1984 K2500
Offline Tazman
« Reply #3 on: January 20, 2017, 07:04:30 pm »
After ordering replacement sockets I found the original was fine. It had become loosened and did not have good contact to the circuit board. Retightened it and all is well.
God BLESS AMERICA
