Author Topic: 87 Chevy crew cab build Ls swap with lots of pics  (Read 240636 times)
Offline ehjorten
Re: 87 Chevy crew cab build Ls swap with lots of pics
« Reply #165 on: July 19, 2017, 06:19:45 pm »
I searched for about 3 years to find the 1991 I wanted, specifically for the 4L80e and the round pattern NP205!
I've contemplated going 36" or 37" tires.  I have full articulation and zero rub issues and I did not want to cut any body work.  Plus...no step bars!  It keeps the shorties out, and I have to help my wife up in it by grabbing her a&$! Lol
« Last Edit: July 19, 2017, 06:22:18 pm by ehjorten »
-Erik-
Offline hwh
« Reply #166 on: July 19, 2017, 06:58:46 pm »
thats funny gives you good reason to grab it. as they get older they dont like that, but you have a reason lol. i did get a used 35 and 37 mounted on the wheels im using to see the difference so i know for sure. but pics on your build helped alot.
Offline hwh
« Reply #167 on: July 19, 2017, 07:04:46 pm »
little update. driveshafts are ordered.  power steering, gearbox, and hydroboost hoses will be getting made soon. and ordered 2 magnaflow mufflers. be true dual exhaust with no cats. if i have problem passing inspection ill add the cats but hoping not.
Offline hwh
« Reply #168 on: July 19, 2017, 09:05:21 pm »
Pics of high angle drivelines ebrake kit for the transfer case.
Offline hwh
« Reply #169 on: July 21, 2017, 08:30:01 am »
One thing half to figure didn't even think about is 4l80e is longer than turbo 400. So my shifter for the np205 won't go back in hole in floor. And I don't want to move seats back. I saw some people heating it up and bending it but think on mine will half to be longer also. Don't think just bending it will be enough.
« Reply #170 on: July 21, 2017, 12:56:06 pm »
It may not go in the same hole but the 4l80/205 did come stock in 91.
It's a good thing I have long legs cause I moved my 4l80 back 3" and the 205 shifter doesn't interfere with the seat if it all the way back
Offline hwh
« Reply #171 on: July 21, 2017, 06:29:29 pm »
I wonder if the shifter on the 1991 crew cab is a little different. Not that I could find one lol. Be real hard to find.
« Reply #172 on: July 21, 2017, 10:44:59 pm »
Don't think I took any pictures but from memory they're the same size and all
Offline hwh
« Reply #173 on: July 22, 2017, 01:58:33 am »
OK thanks for the info
Offline roundhouse
« Reply #174 on: July 22, 2017, 10:58:03 am »
ehjorthen yea thats nice truck. glad you choose ls swap lol. i started out going to do cummins swap but thought in long run be happier with ls swap. since this is going to be my daily driver. glad i saw you build gives me good pics of your truck with 35 inch tires. you have 8 inch lift. doesnt look bad with 35 inch tires. i wan to run 35's for main reason its a daily driver. but just dont want the huge gap between top of tire and bottom of wheel well. looks like 35's will work for me and too i have a 4 inch suspension and 1 inch body lift. i dont like body lifts. so i did the 1 inch body lift just for extra clearance for exhaust and the high angle transfer case ebrake.
We have a 4" spring and hockey pucks on the body mounts
(No need to pay $$ for a body lift when hockey pucks are free )
And 35s and they fit fine
A little fender trimming and you could use a 2" suspension lift with 35s
Offline hwh
« Reply #175 on: July 23, 2017, 08:25:39 am »
Yea it looks about right. Thanks for the pics
Offline hwh
« Reply #176 on: July 26, 2017, 12:28:50 am »
Exhaust is getting put on this week. I went with Gibson mufflers. Didn't want it to loud. Mufflers will be just passed cab and dumped before rear axle. So it doesn't show out back.
Offline hwh
« Reply #177 on: July 27, 2017, 02:29:48 pm »
Truck has power now. Headlights, horn, tail lights all working. Rearview mirror with temperature and compass are working. Showing 100 degrees and that's about right.
Offline hwh
« Reply #178 on: July 29, 2017, 12:56:01 pm »
4wd shifter was modified to go back in hole added to it from underneath so doesn't show in cab.
Offline hwh
« Reply #179 on: July 29, 2017, 12:58:17 pm »
Exhaust about done. Mufflers are just pass cab and dumped at rear axle.
