Author Topic: 87 Chevy crew cab build Ls swap with lots of pics  (Read 240638 times)
Offline hwh
Re: 87 Chevy crew cab build Ls swap with lots of pics
« Reply #195 on: August 03, 2017, 12:44:15 pm »
Ehjorten you might try these guys for headers. Schoenfeldheaders.com
Offline ehjorten
« Reply #196 on: August 03, 2017, 03:18:21 pm »
That is what I have!
-Erik-
Offline hwh
« Reply #197 on: August 03, 2017, 05:20:30 pm »
Oh OK lol
Offline hwh
« Reply #198 on: August 04, 2017, 02:43:19 pm »
Got the wire pigtail for the 4wd indicator for np205 in today. The painless harness didn't have right plug for the np205 which is understandable. Got it from torque king 4x4 they have been best source for np205 parts. Got everything from them when I rebuilt the np205. I was having problems finding the 4wd indicator sensor goes on top transfer case. And found they had it.
Offline hwh
« Reply #199 on: August 05, 2017, 02:06:09 pm »
Cooler lines are connected. All lines are done now. And heat sleeve was put around transmission lines around exhaust.
Offline hwh
« Reply #200 on: August 05, 2017, 09:59:36 pm »
Got the swing case toolbox in today. Going this route cause don't want toolbox taking up bed space.
Offline ehjorten
« Reply #201 on: August 07, 2017, 01:44:44 pm »
I made my own pigtail as I have weatherpack and metripack crimpers and components.  I am still waiting on my replacement 4wd indicator switch though.  Summit says 8/22 for the ship date and I ordered on 7/3.  Might have to check-out Torque King!
-Erik-
Offline hwh
« Reply #202 on: August 07, 2017, 02:06:20 pm »
Yea lol. I got pigtail in 3 days. I've ordered alot from them for np205.
Offline hwh
« Reply #203 on: August 07, 2017, 02:08:17 pm »
Truck is alive and running it started on first crank. So far nothing leaking. Can't post video on here so can't hear it.
Offline hwh
« Reply #204 on: August 07, 2017, 08:06:53 pm »
Driveshafts were ready today. Things moving right along. A/c is charged with freon, blowing cold.
« Last Edit: August 07, 2017, 09:18:49 pm by hwh »
Offline hwh
« Reply #205 on: August 08, 2017, 04:49:05 pm »
Driveshafts are bolted up.
Offline hwh
« Reply #206 on: August 08, 2017, 04:52:28 pm »
Got to find some 7/16 countersunk bolts to bolt front part of rear driveshaft the bolts they sent with transfer case brake hitting brake.
Offline hwh
« Reply #207 on: August 08, 2017, 05:49:35 pm »
Brakes and hydroboost all bleed and working. Truck has steering and brakes now.
Offline ehjorten
« Reply #208 on: August 08, 2017, 08:36:13 pm »
What did you end up running for your AC pump and brackets?  I really wanted to use the stock denso on the LS in the low position, but wasn't ready to chop up the passenger's side engine mount to make it fit.  I am just going to run AC up high, but there are too many options.  What did you do?  Looks like a new pump.  What kind?  What brackets?
Thanks!
-Erik-
Offline hwh
« Reply #209 on: August 09, 2017, 04:11:45 am »
I used the highmount a/c brackets from ICT billet. The one for Ls truck motor. And on compressor used the one came with vintage air kit 944181 and just told them needed the compressor with serpentine belt
 Ordered that kit from jegs. I'll find the receipt from jegs to get part number on compressor. Pretty sure was sanden 508 with serpentine pully.
« Last Edit: August 09, 2017, 07:58:09 am by hwh »
