Author Topic: 87 Chevy crew cab build Ls swap with lots of pics  (Read 240635 times)
Offline hwh
Re: 87 Chevy crew cab build Ls swap with lots of pics
« Reply #210 on: August 09, 2017, 04:26:04 am »
The vintage air part number for compressor I used is 04808-vma.
Offline hwh
« Reply #211 on: August 09, 2017, 03:13:16 pm »
Front part of driveshaft on rear is on.
Offline hwh
« Reply #212 on: August 09, 2017, 04:56:04 pm »
Pics
Offline hwh
« Reply #213 on: August 10, 2017, 02:59:54 pm »
All guages working and everything checks out good on Dakota guages. Truck was idling for 45 mins with a/c on. And never got hot. Everything working as should.
« Last Edit: August 10, 2017, 03:06:16 pm by hwh »
Offline hwh
« Reply #214 on: August 10, 2017, 03:20:56 pm »
Pics
Offline hwh
« Reply #215 on: August 11, 2017, 02:59:12 am »
Shift linkage will be going on next. Going with lokar linkage
Offline hwh
« Reply #216 on: August 12, 2017, 12:11:45 am »
All wires for speakers, radio, and amp are ran. Every wire in truck is sleeved in conduit.
Offline hwh
« Reply #217 on: August 12, 2017, 12:12:33 am »
Pics
Offline hwh
« Reply #218 on: August 12, 2017, 03:00:03 pm »
Everything done on motor side. Brakes, steering, and its shifting in all gears smooth. Time for spray in bed liner.
Offline hwh
« Reply #219 on: August 12, 2017, 03:04:21 pm »
Pics
Offline hwh
« Reply #220 on: August 13, 2017, 06:13:22 pm »
Pics of shift linkage
Offline hwh
« Reply #221 on: August 13, 2017, 06:14:51 pm »
Engine bay is done everything is on
Offline hwh
« Reply #222 on: August 13, 2017, 06:15:29 pm »
Going to clean and repaint underneath. Axles, suspension, etc. And clean inside cab. From the aftermath of the paint and body. Then start putting everything outside on bumpers, mirrors, etc.
Offline hwh
« Reply #223 on: August 13, 2017, 06:22:47 pm »
Found a headliner out of dually about a month ago had to drive 2 1/2 hours to get so hard to find. My truck didn't have a headliner. Dropping headliner off Monday  to get redone. So can get that on before start putting all stuff on inside.
« Last Edit: August 13, 2017, 06:24:34 pm by hwh »
« Reply #224 on: August 14, 2017, 07:12:09 am »
Which spray in liner did you use? Are you happy with it?
