Author Topic: What is the best adjustment for engine TIMING ?  (Read 5099 times)
Offline plik
« on: January 20, 2017, 10:52:53 am »
What is the best adjustment for engine timing?
Is it exactly at 0, or do you like to set it a little before or after that?
And I'm just talking about regular daily driving -- in city, with occasional freeway stretches. I'm not towing, I'm not off-roading.
I have a 1987-1995 GM 350 5.7 TBI on a K20 (3/4 ton suburban) with 35 inch tires.
Re: What is the best adjustment for engine TIMING ?
« Reply #1 on: January 20, 2017, 06:22:20 pm »
TBI is set to zero and the computer controls the advance.  You have to disconnect the wire in the loom by the brake booster to set the timing.
Offline plik
« Reply #2 on: January 26, 2017, 12:59:28 pm »
Clarification on the original question:
I've always set mine to 0, but I wondered if anyone modified theirs at all to a number other than 0.
« Reply #3 on: January 26, 2017, 01:43:58 pm »
For emissions testing it's best to set at zero, although up to 2° BTDC is generally allowed.  For a slight improvement off the line and at low speed around town, up to 6° BTDC might work for a daily driver as long as there is no associated engine ping.
