Author Topic: What rim dimensions would fit?  (Read 11620 times)
Offline m3talc0re
    • Burning Concept
« on: January 21, 2017, 08:54:28 am »
83 GMC Sierra Classic
Currently it has 15" stock rims with 235/75r15 tires. I'm wanting to go up in size, say, 17" rims. What rim dimensions would fit? Like, with offsets, back spacing, etc.. I saw a set of Jeep rims on Craigslist for example. They were 5x5 lug pattern, with a 4" backspace I think is what it said. No idea if that would fit. As for tire size, I'd probably keep around the same diameter, maybe an inch or so larger.. Maybe wider too, like 255 or 265
Re: What rim dimensions would fit?
« Reply #1 on: January 24, 2017, 02:31:37 pm »
My wife owns a Jeep, pretty sure they won't fit
Anthony with 4-5" back spacing should fit depending on width.  I am running Impala SS wheels on mine and they are 17x8.5 with 5.25 back spacing.
squarebody.biz
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #2 on: January 24, 2017, 06:37:19 pm »
I'm pretty sure our trucks are 5 on 5.5" for 2wd.
As you said your not likely to change overall diameter or width too much, the stock backspacing will work, and allow for a little extra room for wider and taller tires. If you go much wider and taller on your tire, then you need to start looking at backspacing as that is when things start to hit on the backside.
 1986 Chevy K30(under repair)
Offline m3talc0re
    • Burning Concept
« Reply #3 on: January 24, 2017, 07:48:06 pm »
I can't remember where, but I read that on mine, they're 5x5 lug pattern. Tire Rack lists my rims as such, too. Captkaos, what size tires are you running with that? At some point, I do want to get 17" rims on mine. Wider tires, though.
« Reply #4 on: January 24, 2017, 09:42:21 pm »
All of these trucks were 5 x 5" wheels.
I am running 275/55/17's
Offline Rapid Roy
  • Euless, Texas
Mopar by Birth
Chevy by Choice
Offline m3talc0re
    • Burning Concept
« Reply #6 on: January 25, 2017, 06:28:11 am »
I like those. Definitely something I may shoot for.
« Reply #7 on: January 25, 2017, 06:30:01 am »
Your right, my Cherokee is a 5 on 4.5, all I remembered was it was a 1/2" smaller
Sent from my LGL34C using Tapatalk
« Reply #8 on: January 25, 2017, 08:06:58 am »
The new 2007-up Wranglers went to 5 on 5".
There is no reason to measure a 73-87(91) I assure you they are ALL 5 on 5".
Offline m3talc0re
    • Burning Concept
« Reply #9 on: January 25, 2017, 08:25:15 am »
What rims are those captkaos?
« Reply #10 on: January 25, 2017, 12:31:28 pm »
94-96 Impala SS wheels.
squarebody.biz
