Author Topic: Transmission Cooling Line Replacement  (Read 3826 times)
Offline dtaylor7897
« on: January 29, 2017, 10:13:37 pm »
Hola guys
In hooking up my trans cooling lines to my new 700r4, I kinked one of them and now it is leaking. I found them pre-bent for $55 + $20 in shipping, but I feel like that's a bit steep. So do you guys think I could fix the leak, or should I go for a new one?
If I can't fix them, I was thinking about making my own. Are they super high pressure or can I just use some left over fuel lines and add some fittings on the end? I'd appreciate some expertise from someone who has done this.
If it matters, 79 K20 Suburban, just swapped from TH400 to 700r4.
Thanks
« Last Edit: February 08, 2017, 10:14:52 am by bd »
Re: Transmission Cooling Line Replacement
« Reply #1 on: January 29, 2017, 10:22:52 pm »
I always make mine, Autozone has the right stuff and easy to work with
« Reply #2 on: February 08, 2017, 09:25:39 am »
make sure you use hose thats made for ATF
