Author Topic: Lower 87 Chevy  (Read 6973 times)
Offline Jerr-conn
  • Retired tool maker
Lower 87 Chevy
« on: February 02, 2017, 08:35:44 am »
I'm new to lowering trucks, so bear with me. On my 87 r10 Chevy 1/2 ton 2 wheel drive short
Box, I want to be conservative, so l'm thinking of cutting 1 full coil from front springs, and on rear
It sits quite high now as it has 5/1 rear springs. I want to remove 2 leaves , meaning #2 and #4
Of the longest leaves. How much will I gain here?Also, I bought 2" shackles for rear. Will I have to remove part of box frame brace for shackles? I'm hoping to level out truck to 2"  drop from front cut coils. Am l in the ball park or not? Will I need new shocks for rear? Appreciate any suggestions. Thanks.   Jerry
Jerry
Offline MrFiveOh
  • The Local Po-Po
Re: Lower 87 Chevy
« Reply #1 on: February 02, 2017, 12:50:28 pm »
1 cut coil will equal a 2 inch drop in the front. If you have a drop shackle in the rear you will have to notch the bed where it comes down lower otherwise the shackle will hit the bed. wont need new shocks.
1974 C-10 AKA "Smurf"
Offline Jerr-conn
Re: Lower 87 Chevy
« Reply #2 on: February 03, 2017, 06:46:32 pm »
Thanks mr fiveoh-----any idea how much extra drop I will get by removing the 2 spring leaves?
Jerry
Offline MrFiveOh
  • The Local Po-Po
Re: Lower 87 Chevy
« Reply #3 on: February 03, 2017, 10:36:48 pm »
Not sure man, but you can find out by measuring from center of spindle to the bottom of the wheel fender. 19.5 inches is factory. thats for front and rear. I do know some trucks came with as many as 7 leaves while some like mine came with only 3. If anything I would remove the overload spring (thick flat one)
