Author Topic: SBC frame motor mount question  (Read 3394 times)
Offline ant305
« on: February 10, 2017, 10:18:33 am »
Hello all, I bought a 1974 c10 that has an Olds 403 in it. This is the most butchered install I've ever seen. The frame motor mounts are in different locations and destroyed.
I bought new motor mounts but since they were in different mounting locations, I don't know what to use. I'm installing a sbc. There is already a th350 in there. Anyone have any pics of there engine mounts with a sbc that was removed?
Just in case I'm not explaining myself correctly, I attached a picture. Please disregard the message and dots. As you can see there are two top holes on the frame, then a lower set. Do the mounts for a sbc belong on the upper, lower or does it not matter?
Offline Stewart G Griffin
Re: SBC frame motor mount question
« Reply #1 on: February 10, 2017, 08:30:28 pm »
Are your frame perches original or correct to the truck or is they oldsmoboggie?
i don't know if these pics will help?  But they are for sbc into a truck.
« Reply #2 on: February 12, 2017, 09:14:00 am »
There are numbers 6 and 8 marked on the perch.
