Author Topic: Axle Identification  (Read 13158 times)
Offline munztead
Axle Identification
« on: February 14, 2017, 07:52:26 am »
Good morning all! Having difficulty identifying the rear end I'm rebuilding. Just finished grinding down all the rust and finally found some numbers stamped. The number read as follows: BR3 G147 2. Tried search the web, but not able to narrow down year, gear ratio, etc. Pics are attached.
Any help would be greatly appreciated.
Re: Axle Identification
« Reply #1 on: February 14, 2017, 08:06:23 am »
Can find what BR3 is but i breaks down like this:  If you want to know the ratio and you are rebuilding it, pull the cover rotate the ring gear and find the 2 numbers.
BR3 = Ratio
G = Plant ( Detriot Gear & Axle)
147 = 147th day of year
2 = shift
Offline munztead
« Reply #2 on: February 14, 2017, 08:44:41 am »
Thanks Chris. Anyway to determine what year it was built?
Offline blazer74
« Reply #3 on: February 14, 2017, 07:23:03 pm »
The center housing I believe is the only way to determine years using casting #'s.
Need to do some research on that.
The tubes are added per application  and stamped with ratio's and build dates but not years to my knowledge.
Offline hatzie
« Reply #4 on: February 14, 2017, 11:48:26 pm »
You can find Axle Identification codes in the GM parts books.  Download em from my signature or search em online at http://www.gmpartswiki.com
Don't mistake these for RPO codes on your SPID tag. Axle stamps are different animals.  Engine, transmission, and transfer case stamp codes are also in the parts books.
BR3 = 1984-1986 C1 or 1987 R1 chassis 2.73 gears in a 8.5" Corporate 10 bolt non locking diff with 11x2 brakes.
« Last Edit: February 15, 2017, 06:01:39 am by hatzie »
