Author Topic: Front Shock Help  (Read 3793 times)
Offline raul7211
Front Shock Help
« on: February 16, 2017, 07:53:05 am »
Hello everybody - new to the forum!  I have an 82 2wd C10; when I bought her, she was already bagged in the front - only bagged, no shocks.  Clearly the ride is a bit too bumpy, so decided to add shocks.  This is where I need some help, where is the stock shock location?  The truck has stock arms and all that, just bags now - I just can't see where they would go.  Also, looks like the shocks only came with one 'bolt' - I assume they figure that you would re-use the existing one for the bottom, but what if you don't have one?  Is this something I can buy on   or just use any bolt to hold in place - thanks in advance!
Re: Front Shock Help
« Reply #1 on: February 17, 2017, 07:49:50 am »
The shock bolts to a stud on the side of the frame and then through the spot on the lower control arm with a bolt.  All my shocks came with new bolts.
