Author Topic: Power door lock relay  (Read 71485 times)
Re: Power door lock relay
« Reply #15 on: December 31, 2017, 11:25:11 am »
check eBay
http://www.ebay.com/itm/1978-87-Monte-Carlo-Regal-Cutlass-Power-Door-Lock-Relay-NOS-/391693085403?hash=item5b32ba2adb:g:bYcAAOSwImRYWH~g&vxp=mtr
What's wrong with yours? Remember they are case grounded so they need to be rigidly attached to the bracket by the column.
_____________
So we cut the old relay out and now I can't get the "new" one rigidly attached for a good ground.  Any suggestions?
What do you mean? It's bolted in, you just remove the bolt and tighten the bolt to install. What did you cut?
Offline Jheald65
« Reply #16 on: December 31, 2017, 06:34:35 pm »
Ok thanks , is possible that the relay will fail and only lock the doors , and not unlock them.? I’ve replaced both switch’s with the same result
« Reply #17 on: January 01, 2018, 08:44:33 am »
Why did you replace the switches? Have you tested anything yet? Just follow the diagram with a test light. the most common failure are broken wires in the door jamb
Offline Jheald65
« Reply #18 on: January 03, 2018, 07:14:07 pm »
I have a lot of extra parts laying around the garage from other trucks , took a couple minutes to swap out switches and rule out that the switches themselves are bad . Since I know that they are good , I can move on to other things like the wires in the door etc .... which I’ll be doing next .. thanks guys ....
Offline Jheald65
« Reply #19 on: January 22, 2019, 09:42:10 pm »
After a small amount of research, the door lock relays are the same for a great number of cars and trucks, got one from a gm car
