Author Topic: rear brake line fittings  (Read 5265 times)
Offline ucstepside
« on: February 19, 2017, 09:06:48 pm »
I have a 78 4x4, I need to replace the rear brake lines. Any tips on removing the brake fitting on rear wheels? I tried PB blast and heat with no luck. Any suggestions would be helpful.
Thanks in advance.
Offline gunrac
Re: rear brake line fittings
« Reply #1 on: February 19, 2017, 09:21:57 pm »
new wheel cylinders
Never Apologize..........as it shows signs of weakness
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« Reply #2 on: February 19, 2017, 09:36:48 pm »
since you are replacing the brake lines.cut them off at the fitting.tap the the end of the flare nut with a hammer and use a 6 point socket or a six point boxed end wrench.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #3 on: February 20, 2017, 06:50:56 am »
new wheel cylinders
This, chances are if your replacing the lines, and you haven't done rear cylinders in the past 12 months, the inside of the cylinders will be all filled with crud.
Short of that vise grips work too if a six point socket keeps slipping.
 1986 Chevy K30(under repair)
