Author Topic: Wheel balancing  (Read 15218 times)
Re: Wheel balancing
« Reply #15 on: March 05, 2017, 04:08:25 pm »
The inner liner of the tire is not intended to be subject to constant bead blasting. If you don't use a balance bead intended for that usage you may end up with a tire explosion.
Re: Wheel balancing
« Reply #16 on: March 05, 2017, 04:09:30 pm »
What size tires are you running anyway?
Re: Wheel balancing
« Reply #17 on: March 05, 2017, 04:18:54 pm »
and different metals in contact with each other will mean corrosion
Offline Dr_Snooz
Re: Wheel balancing
« Reply #18 on: March 05, 2017, 08:48:15 pm »
I learn something new every time I log on here.
Offline roundhouse
Re: Wheel balancing
« Reply #19 on: March 05, 2017, 10:19:36 pm »
Metal beads or ball bearings constantly rubbing against aluminum rim might not be good
High quality airsoft beads seem to be the best and cheapest
Offline Stewart G Griffin
Re: Wheel balancing
« Reply #20 on: April 30, 2017, 05:55:20 pm »
UPDATE:
i want to make a little update if i could;
i had a vibration problem for a while.  Since i'm a cheapskate and the vibration wasn't THAT bad,   (Actually, i was very noticeable, but again i'm a cheapskate) i put it off until last week, where it just got TOO bad.  (also see the other thread, "best inexpensive tires for everyday driving.")
In the process of trying to determine the problem i noticed that i forgot that i had used the Counteract balancing beads in three of the wheels.  The forth was Hunter road force balanced which i think is wonderful.   But i wanted to try the counteracts.
It was determined that one of the tires had bad bulges in it and this was the cause of all the vibration all along.   i recently replaced this tire and put the balancing beads back in, and the truck now rides pretty smoothly.
So, based on my experiences, these balancing beads do seem to work:
http://www.counteractbalancing.com/
