Author Topic: Seat Fitment Questions  (Read 9426 times)
Offline Area51Customs
« on: February 24, 2007, 07:19:00 am »
Hey guys, I bought a set of 89-91 Suburban Bucket Seats off of Ebay.  They bolt to the floor of my 74 C30 on the outside set of holes (near the doors) but the inside tracks are far from touching the floor.  Are there floors in different year trucks different?  Can I get the appropriate seat tracks or do I have to space and mount these?  Also...... I wanted to move my front bench to the rear, but the brackets on my front bench won't interchange with the brackets on the rear bench (different frame).  Can I switch covers, and foam from seat bottom to seat bottom?
Offline bigblock73
  • Yeller
Re: Seat Fitment Questions
« Reply #1 on: February 25, 2007, 11:46:00 am »
Here is some good reading for you.
www.73-87.com/7387garage/...uckets.htm
I do not know the answer about the front to rear seat swap..but I doubt it would be that easy.  I am not even sure the two seats are the same width.
Jeff
'73 swb 2wd
73-87.com
Jeff
'73 swb 2wd
73-87.com
Offline fxjnkmn
« Reply #2 on: February 26, 2007, 09:20:00 am »
There are 2 small stands in sub with buckets for the center bolts they were welded in the one I took them out and bolted the floor of my 86 c10 it worked great. Don
Offline roundedline
« Reply #3 on: March 01, 2007, 04:04:00 pm »
As stated, you HAVE to get the inner seat mounts from the Burb for it to work on a pickup.
If we are talking about Crew Cabs, the front and rear seats are NOT the same size.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 80stepsideguy
« Reply #4 on: March 04, 2007, 09:52:00 pm »
Look on ebay i just bought a set of front seats with the floor brackets for 10.00 i am not kidding i paid 10.00+ shipping, you can find them i did..
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline Fast68
« Reply #5 on: March 21, 2007, 08:45:00 pm »
i believe in about 77 the floors changed and so did seat mounting design too
i know this stuff  changed in the k-5's, including the floor shape/contour.
good luck
Offline roundedline
« Reply #6 on: March 22, 2007, 12:14:00 am »
The floors on pickups are the same from 73-87.
Blazer/Jimmy floors did change, but they won't as a donor to a pickup.
Project Su
Jimmy 2WD Project
« Reply #7 on: March 22, 2007, 03:05:00 am »
Can anyone give a pic on the seat tabs on where they go on the floor?The guy i purchased the seats from used a torch to cut the floor tabs out so i need to use a spot weld cutter to remove the bad metal and like to know where they go so i can weld them in.
thanks
pat
Offline roundedline
« Reply #8 on: March 22, 2007, 03:02:00 pm »
Once you bolt one side of the bracket down it will be self explanitory on where the seat braket goes.
73-87.com/7387garage/inte...uckets.htm
Project Su
Jimmy 2WD Project
