Author Topic: Automatic shift handle remove  (Read 5967 times)
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« on: March 22, 2017, 12:13:44 pm »
I want to remove the automatic shift handle on the steering column in my truck, a 1985 GMC K1500, I converted to an SM465. Do I have to remove everything to do so? Or is just drilling out the pin going to work? My column is tilt, and non of my other columns have this feature. I have been trying to search out the info, but no luck, and have had absolutely NO luck trying to find a manual tilt column(all right I found ONE, but the guy was keeping it for his truck).
 1986 Chevy K30(under repair)
Offline fitz
Re: Automatic shift handle remove
« Reply #1 on: March 22, 2017, 01:45:26 pm »
The pin will push up from the bottom (no need to drill it out).  The chrome shift handle will pull right off once the pin is removed.
« Reply #2 on: March 22, 2017, 02:02:03 pm »
Perfect, bottom of the pin looked liked it was flared out, much better that I don't need to drill it out.
