Author Topic: 350 idle drops after hard drive  (Read 4614 times)
Offline Jakethesnake73
« on: March 25, 2017, 02:19:23 pm »
After i drive down the highway against the wind the truck drops in idle when i stop.  Also i have my idle at 800ish when i hit the gas really quick from a stop and let off it wants to die or does die. I have a new fuel pump and filter. Could this be a carb issue? Im thinking its more related to plugging of the in tank screen.  It runss great oherwise
Sent from my SAMSUNG-SM-G891A using Tapatalk
Re: 350 idle drops after hard drive
« Reply #1 on: March 25, 2017, 02:22:21 pm »
I would look at your linkage, it sounds like it may be hanging up and not fully dropping off the high idle cam.  At least that is where I would start.
« Reply #2 on: March 31, 2017, 10:17:05 pm »
transmission?
is the 800 rpms set at cold?
year, make and model?
« Reply #3 on: March 31, 2017, 11:36:32 pm »
Other possibilities are weak idle solenoid, worn throttle shaft bore, poor state of engine tune....
Offline travisr1988
« Reply #4 on: April 01, 2017, 10:46:36 am »
I have the opposite issue most of the time. Sometimes the idle will drop, but it usually just keeps building up as I drive, it'll start at 750 warm, then after 10 minutes of traffic it will be at 800, then 900, then 950, then I have to shut it off in gear or it will diesel, and even then sometimes it picks up enough to diesel in gear although that's rare. The timing is at 2° advance, new distributer, old quadrajet. The carb is likely the issue in my case as I can adjust the idle mix screws with no change until either the throttle opens and closes or I shut it down and restart it.
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
« Reply #5 on: April 01, 2017, 03:44:07 pm »
i would be looking at a vacuum leak. prob the base plate at the carb or even the throttle bushings
Offline travisr1988
« Reply #6 on: April 04, 2017, 10:23:03 pm »
Irish, I just put a new carb on this weekend and it seemed to have solved that issue as well as many others. It picks up a little idle speed still, but not near as much.
« Reply #7 on: April 05, 2017, 07:23:42 am »
if youre sure theres no vacuum leaks i would set timing and make sure your vacuum advance is hooked up to manifold vacuum and working
