Author Topic: crew cab interior roof trim  (Read 4218 times)
Offline big_al273
« on: March 25, 2017, 06:14:33 pm »
The A pillar and the rear corner pillar trim pieces are the same in the crew cab as those parts in the regular cab correct?
What about the piece on the center pillar between the front and rear doors and above the doors can i use these trim parts from a suburban in a crew cab with the aforementioned A pillar and rear pillar trim?
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
Offline hwh
Re: crew cab interior roof trim
« Reply #1 on: March 25, 2017, 10:42:39 pm »
I'm actually restoring a 87 crew and had these same questions and yes a-pillar and rear cab corner are the same. The pieces above doors will work from a suburban but will need small pieces above the rear door towards back you will have a gap there in between end of piece above doors and rear cab piece. Hope this helps.
« Reply #2 on: March 29, 2017, 07:40:32 pm »
Front and rear of a pickup are the same,  Middle of a suburban will work, but you have to have the transition pieces from a crew.
Quote
the pieces above doors will work from a suburban but will need small pieces above the rear door towards back you will have a gap there in between end of piece above doors and rear cab piece.
We are working on one of that hard to find pieces for the Crew trim AND a complete headliner.
