Author Topic: 1975 C10 Rescue and revive in South Africa  (Read 20327 times)
Re: 1975 C10 Rescue and revive in South Africa
« Reply #15 on: April 01, 2017, 03:55:12 pm »
Looks like it's got the 73-80  rear bumper style.
but the tag says 86... and the website said it was 86
Offline blazer74
« Reply #16 on: April 01, 2017, 04:05:07 pm »
Yep, front bumper is a 81+ just wondered if they used the older style bumper on that bed style.
Offline LTZ C20
« Reply #17 on: April 01, 2017, 11:49:21 pm »
interesting.
Sent from my SAMSUNG-SM-G890A using Tapatalk
LTZ Cheyenne C20
« Reply #18 on: April 02, 2017, 04:31:57 pm »
this is purely a guess but maybe cause the end caps are straight on the bed where the tail lights go? theres no body lines at all its all flush so the 73-80 bumper would be the only one that would fit. if you look at the other trucks theres a curve on the bottom just for the bumper
Offline big_al273
« Reply #19 on: April 03, 2017, 01:15:54 pm »
The Mexican bed is flat across the back but the South Africa truck seems to have the same contours as our North american trucks even thought the tail light is very different
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
« Reply #20 on: April 05, 2017, 07:48:26 am »
ok, so theres a mexican bed and a african bed?
« Reply #21 on: April 05, 2017, 08:53:05 am »
There's a thread on here somewhere with pictures of Mexican versions.
Offline Jason S
Offline Darenwedds
« Reply #23 on: April 08, 2017, 01:07:55 am »
So we made a list of parts required to get our old truck running again.
 Now if you're an American sitting in the USA this task would probably be completed in a single day travelling maybe 30 miles at most to some local stores.
In South Africa however, this little list of parts takes on a whole new meaning when you're 10000 miles away from the USA and looking for 40 year old car parts. Then you are looking for "exotic"  "import" parts from our point of view. So my dad went shopping at some stores where he thought they might still have some old parts available.
And we were totally in luck. To our massive surprise my dad was able to find brand new parts at really good prices. (Bearing in mind our ever weakening exchange rate and severe import duties and taxes).........anything we can find locally is a blessing from above.
 If you can buy a part for a hundred dollars in the USA....... that same part will cost me closer to two hundred dollars once it reaches me in Pretoria, SA. So as boring and mundane as finding parts might seem to someone sitting in the USA....... over here in africa it is a huge victory.......like winning a small lottery prize. Still dreading the partslist of spares that will eventually have to come from the USA as that is gonna be very expensive with our horribly depreciating currency.
Found brand new water pump, fuel pump, rotor, points, carb kit, headlights, spark plug leads and coil.
« Last Edit: April 08, 2017, 02:22:43 am by Darenwedds »
Offline gunrac
« Reply #24 on: April 08, 2017, 12:58:00 pm »
Match books are pretty scarce any more, how are you gonna be able to set the points?.......LOL       Set several sets w/a matchbook. Easier to find then the feeler gauge, more often then not.
I still have 1 engine that requires point's, 13 horse Acme. Italian made, as I understand it. I have it mounted on my log splitter. Every fall I cause them points! Get out the sandpaper an knock the crust off. Only issue I ever had with it. 40+yrs. old.
Never Apologize..........as it shows signs of weakness
Offline Darenwedds
« Reply #25 on: June 05, 2017, 04:27:43 am »
So I have received my south African spec rear tail lights
« Last Edit: June 05, 2017, 04:44:31 am by Darenwedds »
Offline Darenwedds
« Reply #26 on: June 05, 2017, 05:41:48 am »
Also bororowed a BF Goodrich 33 12.5 r15 on outlaw2 wheel to do some measurements. If budget allows I would like to get these same tyres, but on OUTLAW1 solid rims.
« Last Edit: June 05, 2017, 05:53:12 am by Darenwedds »
