Author Topic: Vent window handle  (Read 14215 times)
Offline philo_beddoe
  • 77 C-10
Re: Vent window handle
« Reply #15 on: April 12, 2017, 07:09:30 am »
I just tied a switch into my distributor hot wire.
I've heard of using a switch to send ignition power to horns when trying to start.
That would be cool, i'd like to know how to do that.  But knowing me...my wipers and washer fluid would come on. Lol
« Reply #16 on: April 12, 2017, 07:23:13 am »
If you are looking to break the crank signal to the S terminal on the starter solenoid, go to the NSS instead of cutting wires. This is still easily overcome with a screwdriver so you'd be better off disabling the ignition system. Crank, no start makes noise, floods engine scares away would be thief.
  • 77 C-10
« Reply #17 on: April 12, 2017, 09:05:56 pm »
Ok, what does that entail? Where is the nss located?
