Author Topic: 83 K10 Rear sliding window  (Read 3663 times)
Offline kj4ltc
« on: April 18, 2017, 10:08:04 pm »
I'm working on fixing up a 1983 K10 pickup, one sliding panel is broken out...what are options for replacement?  Is it possible to replace a single section or will the whole window have to be replaced.  Suppliers? Thanks in advance!
Offline gunrac
Re: 83 K10 Rear sliding window
« Reply #1 on: April 19, 2017, 04:58:00 am »
Whole window will need replaced if your depending on using a supplier. I've worked in a piece of plexi more then once. Not pretty, but keeps the weather out.
Never Apologize..........as it shows signs of weakness
Offline haroldwca
« Reply #2 on: August 23, 2017, 09:17:54 pm »
If you can get another sliding window that has a good sliding section, they can be disassembled and then re-assembled with all the good parts in the window you want to use.  There aren't any fasteners holding the vertical bars in place - just friction.  Carefully tap with a rubber mallet and a piece of wood or plastic.  I scored a complete, but weathered RSW from a scrap yard and re-finished it, complete with brush-on clear coat.  Looks like new after a year.
