Author Topic: Bad temp and fuel gauges?  (Read 3747 times)
Offline obwonkonobe
« on: April 23, 2017, 10:57:02 am »
I went through and redid the wiring for my 78 c10, with no tach, but my fuel gauge seems to just do whatever it wants, and once my engine warms up the temp gauge peggs. I bought a new sender from orilies, and put it in the head, but plan on putting it in the manifold. Im getting my 12v and ground to both, and have verified that the signal gets from sender to gauge for temp. If someone could tell me how to test the 2 gauges that'd be great, I have 2 types of temp gauges i can use so if anyone thinks thatll make a difference let me knoe and il send pics, thanks a ton!
Offline haroldwca
Re: Bad temp and fuel gauges?
« Reply #1 on: June 20, 2017, 10:48:25 pm »
As far as the temp gauge goes, the difference is in the sender.  There are two types of senders: analog for gauge, and what might be thought of as "binary" because it is just on/off for the temperature warning light.  The behavior of your gauge (going from one extreme to the other) seems to indicate you have the sender for the warning light.
Using a multimeter set to resistance (ohms), measure the resistance between the terminal on the sender and ground, which in this case could be the head next to the sender.  Just be sure the probe scratches through any paint, rust, grease, etc. Measure the resistance at key off, key on/engine off, and key on/engine on. BE SURE to watch your multimeter leads as the engine fan and accessories rotate.  Monitor the measurement as engine approaches operating temp.  If resistance never changes, or changes abruptly at some point during engine operation, you have the warning light sender.  If the resistance slowly changes as engine approaches operating temperature, you have the analog sender for the gauge.  Inspect your wiring, referencing a wiring diagram in a service manual.
