Author Topic: K10 lift for c10  (Read 17852 times)
Offline JWM_longbedc10
  • Squarebody
K10 lift for c10
« on: April 25, 2017, 11:28:47 pm »
Hey yall, im new to this forum and have a question regarding suspension. I have a 1980 c10 and am having trouble finding a lift kit for it. I want to do a 4 inch lift and all i can find is lifts for k10s. Would a k10 lift work on a c10? If not what else could i do to add some height. Thanks!
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: K10 lift for c10
« Reply #1 on: April 26, 2017, 05:02:04 am »
No way you can lift a c10 4 inches, you can run 1 ton front coil springs with a little work. Gets roughly 2" lift.
Or you can convert to 4wd, then it would look right.
 1986 Chevy K30(under repair)
  • Squarebody
« Reply #2 on: April 26, 2017, 12:35:07 pm »
Would that be enough to fit 35s? What about new leaf springs, current ones are kind of sagging
Offline Al-Haqq
« Reply #3 on: April 26, 2017, 01:39:57 pm »
@JWM_longbedc10 I have the same issue. I have a 86 C10, and would let to lift it, but was told the same thing bout the 1ton springs.
Sent from my Z956 using Tapatalk
Offline Stewart G Griffin
« Reply #4 on: April 26, 2017, 02:15:54 pm »
You may want to research what the donk crowd is doing to get caprices, monte carlos, cutlasses etc. up very high.
.....or not.
« Reply #5 on: April 26, 2017, 03:39:08 pm »
Is your truck 2wd or 4 wheel drive?
  • Squarebody
« Reply #6 on: April 26, 2017, 10:42:48 pm »
its 2wd
« Reply #7 on: April 27, 2017, 05:09:37 am »
Ok, so fronts are coil springs, rear are leaf springs
I would say with 1 ton coil springs you may be able to fit 33" tires, you could do a body lift, and that could net you a few extra inches to fit 35" tires.
  • Squarebody
« Reply #8 on: May 01, 2017, 10:34:56 am »
Thanks, would a 3-4 inch body lift alone clear 33s or maybe 35s?
« Reply #9 on: May 01, 2017, 04:45:47 pm »
I would say with a 3" body lift you could definitely fit 33" tires, not sure on 35" tires though.
Offline roundhouse
K10 lift for c10
« Reply #10 on: May 01, 2017, 11:45:23 pm »
I'd start with a 2" block on the rear springs
And or maybe new springs
The 4 wd rear leafs should fit a 2wd
On the front the one ton springs should get some lift but you could use lift coils from a 4wd vehicle with coils in the front , like a bronco
But living much is going to totally screw up the suspension geometry
But people have been building pre runner type 2 wd pickups for 40 years so it can't be that hard
Hockey pucks are a cheap one inch lift
I wouldn't do more than a 2" body lift
And even that is going to require modifications with the shift linkage , brake lines , steering Column, wiring harness  etc
You can also trim the fenders a little at the bottom corners
Googling "c10 prerunner " and "c10 pre runner "
Brings a lot of info and pictures
« Last Edit: May 01, 2017, 11:47:54 pm by roundhouse »
« Reply #11 on: May 03, 2017, 09:03:03 am »
you can get lifts for the 2wd. they dont make them for our trucks anymore but you can use the lifted spindles from a 88-98 2wd but you have to adapt your truck to the 88-98 style. but im not sure what you have to change, theres a few on here that know the details
AIM industries used to sell 2WD lift kits, and someone has used a 88-99 2WD lift on our trucks...
Rear would just be a std 2.5" lift blocks
Need Bilstein 5100 extended shocks
For the Front:
88-98 Rough Country lift spindles
88-98 Raybestos PG ball joints
88-98 C2500 LD 6 lugs rotors and calipers
Moog 6454 HD Springs
73-87 C30 lower A-arms
73-87 C10 upper A-arm
You will need to ream out the spindle to fit the 73-87 Tie rod ends...
Other than that, your only option is using 1T coils in front and lift springs in the rear.  How big a tire are you wanting to go to?
« Last Edit: May 03, 2017, 11:21:07 am by Irish_Alley »
« Reply #12 on: May 03, 2017, 09:19:48 am »
« Last Edit: May 03, 2017, 09:23:18 am by Irish_Alley »
« Reply #13 on: May 03, 2017, 10:29:35 am »
according to my math thats about 1192.83 to get the parts for the 5 lug. now saying that you might be able to find a donor 92-98 c1500 and use most of those parts and save
  • Squarebody
« Reply #14 on: May 06, 2017, 04:25:57 pm »
Thanks for the help, what about leveling the truck?
