Author Topic: 1980 C10 Pro Street 383 build.  (Read 7280 times)
Offline Sldpulr
  • COLT
« on: May 01, 2017, 04:28:58 pm »
Hey guys and gals. Just wanted to start a build thread for my 1980 short bed. So here is the history.
The truck is a 1980 Short bed Silverado 2WD that I bought from my Father in-law. The truck had been stored in is shop for the past 10 years. It has 80,000 miles and was pretty much bone stock minus the .243 bullet hole in the floor. It still has the functional 8-track player.
So far I have pulled out the blown 305 and installed the motor I originally built for my 69 C10. I do need some help with the motor but ill get that in a later post.
Here is the stats so far.
SBC 383
BORE: 4.030
STROKE: 3.750
DECK HEIGHT: .025
CYLINDER HEAD VOLUME: 72CC
HEADS: 190CC RUNNERS
HEAD MATERIAL: ALUMINUM
GASKET THICKNESS: .032
COMPRESSION RATIO: 10.03:1
PISTON: FLAT TOP SINGLE VALVE RELIEF
CAM: COMP CAM XE294H
TIMING CHAIN: DOUBLE ROLLER
ROCKER ARMS: ALUMINUM 1.5
DIST: MSD PRO BILLET/MSD 6AL
INTAKE: RPM AIR GAP
CARB: 750 HOLLEY DP MANUAL CHOKE
TRANS:TH350C
CONVERTER:3000 STALL
HEADERS: 1 5/8 LONG TUBE
EXAHUST: 3" WITH X-PIPE
MUFFLERS: 3" BORLA OFFSET/OFFSET
GEARS: 3.08:1 (I think)
My to do list as of today
My plans as of right now....
3/5 drop
Weld S71-B wheels 15x6 Front 15x 12 rear
Mini tub
Detroit truetrac
3.73:1 Gears
Fi-tech 600hp Power adder EFI (maybe)
Change to a smoother idle cam. (maybe)
Replace the front windshield.
Change to blue and white paint scheme.
Here is my 69 going to a new home.
Day I brought it home.
Old 305.
Interior.
How i found it.
Getting the motor ready.
Motor going in.
My helper.
Motor in and all cleaned up.
And last but not least the first video of Ole Blue running with the new motor.
https://youtu.be/-jhMZ86fIG8
1980 C10 383 STROKER
Offline Sprinkler-Man
  • 80 GMC Sierra Classic 4x4
Re: 1980 C10 Pro Street 383 build.
« Reply #1 on: May 12, 2017, 12:25:45 pm »
Nice sounding engine.....how are you handling the "lack of brakes" issue now that you have low vacuum?  I have a radical cam in my truck and get one good press of the brake petal.  Gets kinda scary with a 6in lift and 35's.  I took a hydraboost system out of a diesel truck but haven't hooked it up yet.
Offline srozell
    • My 1980 Chevy
« Reply #2 on: May 12, 2017, 06:01:16 pm »
It must be sad seeing the '69 go!
I'm doing a fully body-off resto on my 69' k20 step side, and turning it into my daily driver.
1980 K20 "Camper Special"
1969 K20 Step Side
http://myuglytruck.wordpress.com/
Offline Ntrubbl
« Reply #3 on: May 28, 2017, 05:54:06 pm »
Clean truck sounds really good
Offline smpoulin1
« Reply #4 on: June 24, 2017, 04:43:33 pm »
Nice find! Good looking truck.
85 Silverado 350/700r4
Offline kg264
  • Blucheez
    • Blucheez Leather
« Reply #5 on: July 21, 2017, 06:05:50 pm »
Gorgeous truck, nice engine build!
Sent from my Nexus 6 using Tapatalk
1980 C10 LWB
1962 C10 LB for sale
Looking for a BBC!
