Author Topic: how to tell a cam?  (Read 13207 times)
Offline aprice
how to tell a cam?
« on: August 08, 2005, 11:32:00 pm »
i know a guy through where i work that has two cam shafts for sale. one brand new with no documents, marking, etc for identifing it, and the other is barley used. i told him i'd make an offer next week for both. How do you measure the cam to figure what it is
Offline roundedline
Re: how to tell a cam?
« Reply #1 on: August 09, 2005, 03:45:00 pm »
Depending on what it is, the back of the camshaft at the distributor gear end will have a number and a marking on it indicating the PN or the grind.
If it is slightly used, does he have the lifters it was broken in with?
This is just my opinion, but I wouldn't give over $50 for a used set of cam and lifters, especially one you don't know the specs or history about.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline aprice
« Reply #2 on: August 10, 2005, 07:34:00 pm »
i was thinking the same thing, $50-$75 for both cam shafts. he never said if it had the lifters or not
Offline roundedline
« Reply #3 on: August 11, 2005, 01:42:00 pm »
I wouldn't run new lifters on a used cam.  They have a tendency to wipe lobes off or chew the lifter down.
Project Su
Jimmy 2WD Project
Offline aprice
« Reply #4 on: August 12, 2005, 11:38:00 pm »
thanks, i wouldnt think to run new lifters with a used cam just cause things would be worn unevenly and a spell for engine disaster
