Author Topic: Steering arm bolts  (Read 5408 times)
Offline Watson210
Steering arm bolts
« on: May 02, 2017, 04:24:35 pm »
So 2 of the 3 bolts holding on my steering arm have sheared off. Anyone know where I can get replacements as well as any tips on removing them?
Re: Steering arm bolts
« Reply #1 on: May 02, 2017, 05:46:51 pm »
Offline Engineer
« Reply #2 on: May 02, 2017, 09:24:50 pm »
I am going to assume you are talking about the 3 studs on the left hand steering knuckle of a K-10/20 series?
If so, you won't like my advice but if it were my truck I would replace the knuckle, studs, and steering arm. If the truck is lifted this means buying a lift kit compensated steering arm.
Expensive, I know, but WAY more safe in the long run.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #3 on: May 03, 2017, 08:50:23 am »
im with engineer, if thats what youre talking about. ive swapped knuckles before just because of the amount of work to remove the studs and the damage you could do to the knuckle in the process of removing the studs. i wouldnt buy new i would get one from the junk yard with the arm already attached, if its for a lifted truck then you would just have to get a new arm
Offline Watson210
« Reply #4 on: May 07, 2017, 11:14:30 pm »
That's basically where I was thinking this was going to go. Thanks for the help fellas
