Author Topic: Clock polarity  (Read 3479 times)
Offline fiddler
  • 74 Chevy C10 Stepside
Clock polarity
« on: May 03, 2017, 02:00:39 pm »
I have a 1974 chevy c10 stepside.  I am installing a 1973 gauge housing in much better shape than my old one.  The 73 has a clock.  The 74 does not have the wiring for it.  Which terminal is hot on the clock, the horizontal or the vertical?
Thanks for your response,
ricky
Ricky
Re: Clock polarity
« Reply #1 on: May 03, 2017, 08:25:29 pm »
The 'vertical' terminal (image) should be B+ and the 'horizontal' terminal should be ground.  I suspect an AC Delco PT303 and possibly a PT1501 will connect to the clock with the correct terminal spacing and size, but actual fit needs to be physically verified.
Offline fiddler
Re: Clock polarity
« Reply #2 on: May 04, 2017, 08:24:31 am »
Thank you.  I presently have it wired with terminal lugs, but I would much rather install a connector so I will pick one up next time I am in town.
ricky
Ricky
