Author Topic: Ball joint wear? Whats acceptable  (Read 4951 times)
Offline Jakethesnake73
« on: May 04, 2017, 12:15:05 pm »
My passeger side is good but the driver side moves a little. You cant hear it hit when you check them but put you hand on the tire and you can feel it slightly. Will an alignment hold
Sent from my SAMSUNG-SM-G891A using Tapatalk
Re: Ball joint wear? Whats acceptable
« Reply #1 on: May 04, 2017, 12:49:41 pm »
Any movement is no good and any reputable shop will not align it with worn parts
« Reply #2 on: May 04, 2017, 02:18:28 pm »
could it be your wheel bearing/s?
Offline big_al273
« Reply #3 on: May 05, 2017, 10:17:24 pm »
replace the worn component then get your alignment
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
« Reply #4 on: May 11, 2017, 10:42:21 pm »
Ok sounds good thanks!
