Author Topic: Steering box frame reinforcement kit for 74 chevy c10 stepside  (Read 5143 times)
Offline fiddler
  • 74 Chevy C10 Stepside
So when I first bought this truck a few years ago the guys at the shop where I had air shocks installed found the frame cracked at the steering box.  They welded the frame for me.  The steering seems loose again and I can see the frame move at the steering box.  I want to install a reinforcing kit.  (Both weld in and bolt in).  I found a guy to install the weld in kit.  (I don't weld).  He builds custom truck frames.  I will be paying for his time so I want a kit that will install with no rework to the kit.  Can someone suggest a kit that is a direct fit for a 1974 chevy C10 stepside.  (Obviously from C10....2 wheel drive.)  Power steering.  Automatic.  Thanks in advance for any advice...
ricky
Ricky
Offline blazer74
Re: Steering box frame reinforcement kit for 74 chevy c10 stepside
« Reply #1 on: May 18, 2017, 05:14:32 pm »
Bolt on steering brace 73-80 2 wheel drive.
Do a search they'll come up .
That's the best I can do due the rules.
Fits inside the Frame and fwd crossmember so if the frame has been built up in that area the bolt in brace will not be direct bolt in without some mods.
