Author Topic: Small issue  (Read 6288 times)
Offline 808C10
Small issue
« on: May 25, 2017, 11:25:31 pm »
Can't figure it out, but I just installed drop spring and my driver side is lower by two inches.
What could be the problem?
Re: Small issue
« Reply #1 on: May 26, 2017, 03:27:21 am »
did you move the truck after you installed the spring?
Offline Ntrubbl
Re: Small issue
« Reply #2 on: May 26, 2017, 09:58:38 am »
Probably the higher side spring is not seated in the pocket correctly
Offline 808C10
Re: Small issue
« Reply #3 on: May 26, 2017, 12:48:13 pm »
Irish_Alley yes I did
I'll check again
Thanks Guys
Re: Small issue
« Reply #4 on: May 26, 2017, 02:59:25 pm »
measure the space between the upper and lower control arms. (im grasping here and trying to get as much info as possible)
