Electrical
using 1988 dash with 1995 sensors
Topic: using 1988 dash with 1995 sensors (Read 5989 times)
MuddiGGEr25
Wrencher
May 26, 2017, 10:54:46 pm »
Does anyone know off hand if the reference signals/resistance are the same for the CTS on the 454 TBI and the temp sensor on small block tbi/6.2's? I am trying to figure out where to tap in so i can use the existing dash gauges
It appears that the oil pressure switch (on the 1995) is also the sensor/sending unit according to the wiring diagram, but not sure if the gauge will short out or read properly if i wire that up. or if it will affect the PCM any by having an additional sensor "grounding" the signal
1988 V10 Suburban 5.7L TBI/TH350 39K on rebuild 4.10AR GM14FF/GM10SF 235/85R16 & 18.4-16.1
1988 V20 Suburban 6.2L-J/TH400 CA truck, 125K G80 14FF/ GM10 4.10AR GVWR 8,600
1977 Ford Granada ~450HP 302 2bbl/C4 27K original 2.47 215/70R14
Re: using 1988 dash with 1995 sensors
May 27, 2017, 01:44:42 am »
the signal would be the same (gm used that sensor up till 2009 maybe even longer).
the OPS was used from 90 to 99. dont know if the reading would be the same. i think they would cause in my 91 crew cab i have the same sending unit (or switch) and my gauges are pretty much the same as the 88s
http://forum.73-87chevytrucks.com/smforum/index.php?topic=31456.0
big_al273
May 27, 2017, 04:19:30 pm »
i have a 91 gauge cluster from a parts truck and as far as i can tell the gauges are all the same as previous years with the exception of the fully electronic speedometer
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
MuddiGGEr25
Wrencher
May 27, 2017, 04:48:44 pm »
So i should be able to tap into the CTS for my temp gauge on the dash? I thought my 350 TBI had a seperate sender for the dash signal?? (it was a 1987 block/PCM in a 1988 body)
I will tap into the OPS once i superglue it back up (hopefully that will work, just the plastic housing snapped, nothing inside appears to be damaged) it looks to be a magnetic pickup of some kind that reads off the OP and converts it to a resistance.
May 27, 2017, 05:13:09 pm »
theres two sensors for the tbi units, yes. one goes to the ecm (on the intake) the one in the head goes to the gauge/light the color code will be the same for the gauges.
not sure why you want to tap into the wire. it should be a simple plug and play. a few post up i also attached a link to the cluster wiring harness diagram
MuddiGGEr25
Wrencher
May 27, 2017, 11:45:24 pm »
I want to tap into the wire because i am mating up the 1995 TBI 454 into the 1988 V20 suburban that used to have the 6.2L, and pretty much nothing is preexisting, so im matching up wires from scratch because i was in too much of a hurry to label anything.
May 28, 2017, 03:29:59 am »
no need to tap the wires into place. the cts for the gauge will be the same plug, wire and sensor. it will be a plug and play. dont know if you need to extend the wire but that might be your only problem.
does your 88 not have any wires in it now?
MuddiGGEr25
Wrencher
May 28, 2017, 07:17:14 am »
I sold the 6.2L and TH400 to a kid that was building his first truck for work/school so i cut the entire harness about 16" from where the loom comes out of the firewall to make his life a little easier. its not a big deal to me because it means i dont have all the extra wires still laying around the engine bay, so once i get around to ziptieing the 1995 harness it should look pretty decent, all i need to do is waterproof the PCM since im leaving it on the passenger fender next to the heater box
Its not going to be the most beautiful setup but as long as it runs and drives and gets us to TN safely at the end of the week, thats all i care about
May 28, 2017, 03:19:01 pm »
ok, i understand the issue now. one good thing most the wires in the firewall junction box arnt needed to start and run the truck. another good thing is i know for our trucks gm kept the same wire colors for the same sensors. like the CTS is always green oil should be blue and etcetera. make understand the wire harness much easier. i kind of had to do this when i did my cummins swap. most the wires i didnt have to touch and i want to say i only had to cut the wires not being used.
Electrical
