Author Topic: What Does the TH400/4L80E crossmember rubber do?  (Read 3097 times)
Offline MuddiGGEr25
  • Wrencher
« on: May 28, 2017, 02:12:34 pm »
So I realized I don't have the rubber feet that was from the TH350 in the K5 and I don't have the TH400 rubber mount. I have the cross member already drilled and bolted into the V20 under the 4L80E. Does the rubber "base" or "spacer" serve any other purpose than to center the transmission and give a little flex? The reason I'm asking is because I cannot afford to order one, but I am fabbing up a solid rubber " spacer at work (sugar factory) that's the right height. Just not sure if it has to cope with rotational forces or if the motor mounts are supposed to deal with that.
FWIW. The TH350 I had in the V10 burb that we muddled and towed with for months the rubber was sheared off so the bolts weren't actually holding the rubber to the trans/tcase and it did fine for the 11 months we were driving it
1988 V10 Suburban 5.7L TBI/TH350 39K on rebuild 4.10AR GM14FF/GM10SF 235/85R16 & 18.4-16.1
1988 V20 Suburban 6.2L-J/TH400 CA truck, 125K G80 14FF/ GM10 4.10AR GVWR 8,600
1977 Ford Granada ~450HP 302 2bbl/C4 27K original 2.47 215/70R14
Re: What Does the TH400/4L80E crossmember rubber do?
« Reply #1 on: May 28, 2017, 04:19:24 pm »
you mean the transmission mount? yes you need one and you want it to be somewhat flexible or youll break the tail housing/adapter plate or bell housing
