Author Topic: 454 swap  (Read 4623 times)
Offline woodbryce20
454 swap
« on: May 29, 2017, 11:04:55 pm »
I have a 1985 c10 with a 305 and th350 and was trying to sell it until a buddy offered to flat out give me a clean 400+ hp 454 and help with the install. I really want to do it but what will i have to do do to make it fit? What parts from my 305 are compatible with the 454? Will a 454 bolt to my th350 trans? Can i use my 400cfm edelbrock carb on the 454? Will my edelbrock preformer intake bolt up? Will i have to change my gearing? Any suggestions/ideas would be fantastic.
Offline Rattler12
  • Old Geezer
Re: 454 swap
« Reply #1 on: May 30, 2017, 08:22:21 am »
Unfortunately nothing from the 305 will work on the 454. The TH350 will bolt up to it but from experience I can say it won't last long. The 400 carb is way small for a big block. The intake won't fit. As for the gears they won't know the difference between a 305 or a 454.........you're gas tank and pocket book will though.....although 305's aren't gas misers either  :)
83 C-10 shorty 454, 5spd, 3:73 posi
Offline vjfelix55
Re: 454 swap
« Reply #2 on: May 30, 2017, 12:38:14 pm »
Somebody giving you a BBC is a gift from the heavens. BUT Seeing that you have a 305 almost everything will have to be changed. The th350 will bolt up but I can tell you that poor tranny won't last long. The intake manifold won't fit, the Edelbrock carb will BUT I highly doubt a 400 cfm carb could satisfy that gas's guzzling big block. You'll need new motor mounts. Also let's say you install the 454 and use the fan shroud from the 305, make sure the fan doesn't eat up that shroud. Another thing is the big block weighs a lot more than a 305. You may want to get new front coils for the front assuming its a 2wd or new leaf springs and shocks assuming its 4wd. One thing I will say is I hope you like gas stations. I can tell you that from experience. But in the end the swap will be worth it. Once you go big block you never go back. Anyways hope this helped you, keep up updated on how this goes! Good luck
Sent from my ONEPLUS A3000 using Tapatalk
