Author Topic: Older 379 gas  (Read 15491 times)
Offline scwaters
Re: Older 379 gas
« Reply #15 on: June 04, 2017, 03:45:27 pm »
Sorry this is my first American truck.  Built a number of old Alfa Romeos and British iron.  Appreciate the input.  Would Chevy have called the 379 a 400?
1976 K10 Short Bed/379 cid/Edlebrock 500 CFM
Re: Older 379 gas
« Reply #16 on: June 04, 2017, 03:59:53 pm »
did you google 379 sbc? apparently it is a replacement 350 but the dipstick can be located on either side for that "OEM" look.
Offline scwaters
Re: Older 379 gas
« Reply #17 on: June 04, 2017, 04:07:02 pm »
I'm not sure I know what you mean by a "replacement" engine.  Appreciate some clarification. Try in figure out exactly what I've bought has been very frustrating.  I know the bed is fron a later truck by the tailgate and the fuel door.
Re: Older 379 gas
« Reply #18 on: June 04, 2017, 04:37:03 pm »
dont know thats what i saw on one post but i saw others that said the 379 is the casting date as in march 1979. some say its from a 77-79
Offline bd
Re: Older 379 gas
« Reply #19 on: June 04, 2017, 06:05:00 pm »
VD212800 is not the casting number; it is the engine production code that IDs the year and vehicle application of the motor.
The "379" is the last three digits of the actual casting number, 14016379, which is a 1978 - 1985 small block 350 CID casting used in light-duty truck applications.  Since it is an unmachined casting ID number, the block was used as the base for both 2-bolt and 4-bolt engines.
Irish, casting dates are stamped numbers rather than cast.  Otherwise, casting molds would require modification for each production run.
Offline scwaters
Re: Older 379 gas
« Reply #20 on: June 06, 2017, 04:00:52 pm »
Picture 1of2
Offline scwaters
Re: Older 379 gas
« Reply #21 on: June 09, 2017, 02:07:09 pm »
New Question - with the 379 & Edlebrock (500 cfm) should I still run regular gas.  I hope as I'm getting about 7 mpg at the moment.
Offline scwaters
6.2 gas expectations
« Reply #22 on: June 09, 2017, 02:59:51 pm »
I have heard some disdainful postings about the 6.2.  I assume they were regarding the gas engine.  I have one in my recently purchased 76 sb.  it doesn't have a lot of grunt and the current mpg is somewhere about eight, 1403 Edlebrock (500 cfm) with dual exhaust.  What should I expect; durability? performance? mpg? I'm just learning, appreciate any insight.
Offline dphipps
Re: Older 379 gas
« Reply #23 on: June 09, 2017, 06:28:48 pm »
It's a 350ci as explained above.
Offline csdineley
Re: Older 379 gas
« Reply #24 on: June 09, 2017, 06:38:41 pm »
Agreed it's a 350. 379 is the block casting number not the displacement. Since your vin says it came with a 400. Most likely a rebuilt or crate motor.
1987 V20 Custom Deluxe, Vortec Headed 350, SM465,Np205 14Bff 4.10
Offline Stewart G Griffin
Re: 6.2 gas expectations
« Reply #25 on: June 10, 2017, 11:47:16 am »
Again, not to be a jerk, but again, you DO NOT have a "379" engine.  No such gas engine exists as far what was available in this series of trucks.
i don't have time to get into detail, but perhaps this could help:
https://en.wikipedia.org/wiki/Chevrolet_small-block_engine
