Author Topic: Another parts bin truck  (Read 8085 times)
Offline scwaters
« on: June 01, 2017, 01:43:22 pm »
I have a 1976 short bed with a carbureted 379 (yes 379).  The transfer case body is iron and it is massive.  Numbers; 346321GM and either C126 or C\26.  I have to find out what/when my drivetrain is.  Anyone  have any info?
1976 K10 Short Bed/379 cid/Edlebrock 500 CFM
Re: Another parts bin truck
« Reply #1 on: June 01, 2017, 02:38:30 pm »
some times all you have to do is google that part number and first result that popped up
http://www.pirate4x4.com/forum/chevy/659051-what-t-case.html
Offline scwaters
« Reply #2 on: June 01, 2017, 05:16:16 pm »
Thanks to all on the leads.  Turns out it is an NP205.  With the iron case it appears in line with the vintage of the car.  now to solve the 379 CID gasoline engine mystery.  Could GM have marketed the 379 as the 400?
« Reply #3 on: June 02, 2017, 01:08:49 am »
are you sure? that number only comes up as a 203
Offline scwaters
« Reply #4 on: June 02, 2017, 08:44:54 am »
You're probably right.  I have strap plated from the 203 being a full time unit that required conversion.  I stand corrected.
« Reply #5 on: June 02, 2017, 08:50:32 am »
