Author Topic: Need help  (Read 3532 times)
Offline michaelLQJones
Need help
« on: June 05, 2017, 12:15:32 pm »
I recently purchased a 77 K10 Scottsdale with a rebuilt 427. Motor and Tranny work well. Just needs cleaning up and removing rust in body work.
Needing to cut out and weld in new floor pans and rocker panels.
Question is this model has two fuel tanks between the outer bed and frame, one on each side.
Is it recommended to drop fuel tanks before cutting and welding or should I be fine with just covering the tank with a welding blanket?
Any ideas?
Thanks
Mike
Offline srozell
    • My 1980 Chevy
Re: Need help
« Reply #1 on: June 05, 2017, 12:31:30 pm »
It really depends on where you are cutting and welding.
1980 K20 "Camper Special"
1969 K20 Step Side
http://myuglytruck.wordpress.com/
Re: Need help
« Reply #2 on: June 06, 2017, 03:31:15 pm »
About 4-6 inches from fuel tank.
I purchased a welding blanket that I can place over the tank.
Thanks
Offline Jerr-conn
  • Retired tool maker
Re: Need help
« Reply #3 on: June 25, 2017, 08:03:16 am »
It isn't the tanks as much as the fumes. That's hat will ignite first. Drop those tanks.
Jerry
