Author Topic: 5 lug to 6 lug:  (Read 5314 times)
Offline Stewart G Griffin
5 lug to 6 lug:
« on: June 06, 2017, 08:35:47 pm »
Which 6 lug rotors, if any, will fit 1/2 ton spindles?
Or, if different spindles are required to switch to 6 lugs, then which spindles, if any, will fit 1/2 ton A-arms?
This is for the front, we'll worry about the rear later.
Offline m3talc0re
    • Burning Concept
Re: 5 lug to 6 lug:
« Reply #1 on: June 07, 2017, 05:41:00 am »
I would like to know this, too. Rear as well.6 lug rims seem to be a lot easier to find that 5 lug -_-
Re: 5 lug to 6 lug:
« Reply #2 on: June 07, 2017, 05:08:30 pm »
since gm never offered 2wd 6 lugs till 99 nothing with work afaik.
Re: 5 lug to 6 lug:
« Reply #3 on: June 07, 2017, 05:43:24 pm »
Check with the 60-66 groups, I see all kinds of posts putting 6 lug rotors on.
Re: 5 lug to 6 lug:
« Reply #4 on: July 19, 2017, 09:11:23 pm »
The 71-72 C10's used 6 lug rotors.  They make some to fit the 73-87 also.  If you are doing it on the cheap get the 71-72 rotors and spindles and swap them.
