Author Topic: 6.2 high flow water pump?  (Read 35145 times)
Offline Artezio
« on: June 08, 2017, 03:10:19 pm »
Does anybody know if there is a 6.2 high output water pump? I have a 1983 k30 6.2 vin j Detroit diesel v-belt engine with a banks sidewinder turbo system. I've heard horror stories that when you reach a certain engine speed the oem water pump is only sending coolant to the left bank, so to be safe I was trying to find a high flow water pump but I can't seem to find one, peninsular diesel has one for the 6.5 vbelt but I'm not sure if that will fit, any ideas?
Offline fitz
Re: 6.2 high flow water pump?
« Reply #1 on: June 08, 2017, 05:37:27 pm »
How high of an RPM do you plan on reving that 6.2?
I've owned a few 6.2 J codes in CUCV's over the last few years.  I've spent many nights staying up way to late reading everything I could find online about these motors.  This is the first I've heard about water not flowing to the right bank head at certain RPM's.
While these engines do have some flaws, this 1 is new to me.
Hopefully our in-house experts can shed some light on this.
How do you like the Banks Sidewinder?
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #2 on: June 09, 2017, 08:23:42 am »
Pure myth, on the later 6.5 with the dual thermostat and no restricted bypass port, the rear two cylinders see restricted flow.
All hi-flow/volume pumps are fir serpentine systems and are designed to rotate the opposite way(no good for a v-belt.
Making sure you have a good clean and flow-tested radiator is the best cooling upgrade you can do.
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
Offline Artezio
« Reply #3 on: June 13, 2017, 06:34:55 pm »
It only restricts flow when a turbo is equipped because the engine wasn't originally designed for a turbo so a better water pump is required from what I understand. I actually called peninsular diesel and they do have one it's on order and will be here next Tuesday, thanks though! I'm rebuilding the engine so I'm not cutting any corners, coated pistons and all other parts of the highest quality,  rebuilding turbo, new water pump, new injectors, new stronger heads with head studs instead of bolts, and new injection pump. I think that's everything  8)
Offline fitz
« Reply #4 on: June 14, 2017, 03:53:31 am »
Good luck with your project.
I still don't understand how adding a turbo will restrict water flow.
« Reply #5 on: June 14, 2017, 07:12:55 am »
i got some ocean front property in arizona, from my front porch you can see the sea  ;)
Offline Mr Diesel
  • Aaron
« Reply #6 on: March 08, 2020, 01:17:03 pm »
I know this thread is 2+ years old, but thought I would note that high-flow pumps ARE available for non-serpentine belt (v belt) systems. Peninsular Diesel had one, but their company is bought out and the new owner (Unique Diesel) has reopened the Marine division but not the light truck division yet.
I found one through FlowKooler for $139.
https://www.flowkoolerwaterpumps.com/collections/hi-flow-water-pumps/products/1895-1982-1993-chevy-gmc-6-2l-diesel-water-pump
It arrived last week. Looks like a standard pump body with their high flow impeller installed (pretty much like their website indicates).
I did quite a bit of research on the serpentine high flow pump offered by Heath Diesel and their modifications seem to be a closely guarded secret, but I'm pretty sure Heath just puts on a better impeller and jacks up the price a few hundred $$.
« Last Edit: March 09, 2020, 07:42:30 pm by Mr Diesel »
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
