Author Topic: Knocking in the motor  (Read 12114 times)
Offline cfd232
« on: September 19, 2005, 09:10:00 pm »
I was driving my truck on the highway one day. I was going up a hill and the temp. went up on it and i lost power. I pulled off the side of the road and antifreeze poured out of it. The motor is a 350 bored out to a 355. It didnt not lock up, it still starts and everything. What is wrong with it? Also, if anyone wants to buy it let me know. Ill send you pictures.
Edited by: cfd232 at: 9/19/05 8:25 pm
Offline roundedline
Re: Knocking in the motor
« Reply #1 on: September 20, 2005, 10:45:00 am »
What did the oil level look like?  Hard to diagnose without knowing the history.  I would just be guessing.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
knocking
« Reply #2 on: September 20, 2005, 02:47:00 pm »
Where did the antifreeze come out at?  The sounds could be anything.
SgtDel
Offline cfd232
Re: knocking
« Reply #3 on: September 20, 2005, 07:40:00 pm »
The Antifreeze was coming from the radiator.. After it did whatever it did, the oil level was alomst empty (it was full to begin with)
Offline roundedline
Re: knocking
« Reply #4 on: September 22, 2005, 11:56:00 am »
If it ran hot and the oil was almost empty no oil was contributing to it running hot.  If it is knocking now, it is due to the bearings being galled or spun.
Project Su
Jimmy 2WD Project
Offline cfd232
Re: knocking
« Reply #5 on: September 23, 2005, 10:09:00 pm »
There was oil in it when i took off driving it that day, and it dont leak. So i dont know how it got so low in a 45 minute time period.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
knocking
« Reply #6 on: September 27, 2005, 11:10:00 am »
I'd drop the oil pan and have someone turn the crank from the front of the engine w/ a socket wrench.  Observe what is going on from up under the motor. Inspect the bearings and connecting rods, look for play or looseness. That's about all you can do...the next step would be to disassemble to motor and put new parts in.
Offline cfd232
Re: knocking
« Reply #7 on: September 27, 2005, 04:50:00 pm »
ok. I'll try that and see whats going on.
