Author Topic: spraying the inner fenders with undercoat or bedliner  (Read 6641 times)
Offline shaved80
« on: April 25, 2005, 09:38:00 pm »
this seems like a good idea, anyone know if it was undercoat or bedliner used? and what are your opinions on this? i'd do it on the inside of the fenders like the picture, and on the bottom of the inner fenders, then paint the inner fenders to match the body.
Offline bigblock73
  • Yeller
Re: spraying the inner fenders with undercoat or bedliner
« Reply #1 on: April 26, 2005, 07:25:00 am »
I personally wouldn't paint my outer fenders that way....unless I wasn't running inner fenders.  I run inners, and undercoated the underside of them for durability and clean looks.  My outer fenders are painted yellow inside and out...looks sweet IMO when you open the hood.
...Jeff
'73 swb 2wd
'77 Blazer 2wd
73-87.com
Jeff
'73 swb 2wd
73-87.com
Offline shaved80
« Reply #2 on: April 26, 2005, 10:45:00 pm »
i might eventually run without inner fenders, so it'd just be easier to do it right now.
« Reply #3 on: April 27, 2005, 02:12:00 pm »
Why is the inside of that fender hacked out? I have sprayed both sides of the inner fenders with Sem bed liner and the insdie of the outer fenders as well but only the part that is hidden by the inner fender and the cab then painted it to match the truck color.
Offline roundedline
« Reply #4 on: April 27, 2005, 02:28:00 pm »
They are cut out because the truck is bagged and dropped and if they didn't do that it would be sitting on the inner fenders.  Here it is layed out. (It is the truck in the Truckin' Magazine)
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
« Reply #5 on: April 30, 2005, 03:07:00 pm »
Oh, I wouldn't have that problem in one of my trucks. I seam to need to cut out or mash back behind the tire on my rigs!!
