Author Topic: 77 SB Silverado build  (Read 8719 times)
Offline 1970rs
« on: July 07, 2017, 11:14:12 am »
I am fairly new to the forum and pretty new to 73-8 trucks. I have always played with the 67-72, but decided I really like the square bodies and wanted to build one.
It appeared to be in pretty good shape when I bought it. It had new paint, but whoever painted it didn't know how to spray a single stage with lots of metallic. It was tiger striped and mottled really bad. I decided to do a quick paint job on it. Well that is where the snowball started!! I am now neck deep in it. I pulled the interior and found the original carpet and jute padding under the current carpet. Needless to say, they were holding moisture and once I peeled this stuff out, it took half the floors with them (Looked good underneath before pulling carpet)
Anyway, at this point I have replaced both front floors, the pass inner and outer rocker, both front cab mounts and patched the drivers inner and outer rocker as well as replace the drivers cab corner.
Next step is pulling the cab and re-doing the frame etc. I am excited to finish it and get to some of the local shows.
I am building it to be a driver. I want it to be nice, but not so nice I am afraid to drive it.
Here are a few pics as I bought it, some as I am restoring it and a rendering of how it will look after I get done. I am going with steelie wheels for now, but hope to go with a bigger wheel in the future. I am going for modern styling on a classic look.
What do you guys think?
Offline 1970rs
Re: 77 SB Silverado build
« Reply #1 on: July 07, 2017, 11:15:20 am »
More progress pics
Offline 1970rs
« Reply #2 on: July 07, 2017, 11:19:15 am »
More progress
Offline 1970rs
« Reply #3 on: July 07, 2017, 11:20:34 am »
More progress
Offline 1970rs
« Reply #4 on: July 07, 2017, 11:21:34 am »
Here are rendering of how it will look when done.
Next step is pulling cab and engine!!
Offline DanMcG
« Reply #5 on: July 07, 2017, 06:38:09 pm »
Nice truck and great panel repairs, thanks for sharing.
Offline SAMARITAN
« Reply #6 on: July 08, 2017, 07:20:56 pm »
Great job!! Where did you get the repair panels?
Sent from my SAMSUNG-SM-N920A using Tapatalk
1974 C10
305 ci
Fleet side
TKO Five Speed
Offline 1970rs
« Reply #7 on: July 08, 2017, 09:34:36 pm »
All fit pretty decent. As will all aftermarket panels, they will require some tweaking.
Got quite a bit done today. Cab off, engine and tranny out and core support off. Time to degrease the frame.
« Last Edit: July 19, 2017, 08:03:32 pm by Captkaos »
