Author Topic: LED upgrades:  (Read 3549 times)
Offline Stewart G Griffin
LED upgrades:
« on: July 22, 2017, 04:12:50 pm »
Is there any difference between buying an LED bulb vs. buying a complete assembly?   Specifically the tailights, but also in general?
Example:
The technostalgia lights available in the store vs. buying two 2057 led bulbs?
Offline dwightr
Re: LED upgrades:
« Reply #1 on: July 22, 2017, 06:06:23 pm »
The LED bulb will work in the original socket and probably a lot cheaper.one thing that I have noticed in switching to LED is you will probably need to change flasher box to a solid state because they do not draw as much current as the incandescent bulbs causing a quick flash as if you had a bulb out.
Hope this helps.
Offline GMCMedic
Re: LED upgrades:
« Reply #2 on: July 23, 2017, 08:53:14 am »
Not really, i bought LED circuit boards for the brake lights, but everything else is LED bulbs in  the original sockets.
Sent from my SAMSUNG-SM-G920A using Tapatalk
