Author Topic: Spark plug boot style 454 tbi  (Read 3386 times)
Offline robosmurf
« on: July 24, 2017, 02:40:57 pm »
I'm looking to get a set of make your own length plug wires for my 84 that has a engine swap to 454. What is the correct style boot? Just the long straight ones? Currently there's a notch in the boots to flex the cable to 90 degrees.
 I just ordered a set of the correct plug wire retainers, there was only 1 of 6 left and the wires are flopping everywhere.
Sent from my SM-G920V using Tapatalk
84 c20 Camper Special
454ci with TBI
Re: Spark plug boot style 454 tbi
« Reply #1 on: July 26, 2017, 08:03:31 am »
personally i would op for a wire set from autozone or something.
http://www.autozone.com/ignition-tune-up-and-routine-maintenance/wireset/duralast-wireset/40558_712909_0
theyre 8mm and they look like what you have on now. IMO theres no need for "make your own wires" unless you have a performance motor. even then most of the "performance" wires are only 8mm
