Author Topic: Courtesy and dome light problems  (Read 6041 times)
Offline Restoredrustbucket
« on: July 26, 2017, 03:43:51 pm »
Hi, so the courtesy and dome lights don't turn on in my 1986 chevy Scottsdale, there is power to my dome light but nothing happens when I turn the knob CW or when the doors are open, I took out the door switches to test the white ground wire and found that the wire doesn't spark when I hit it to a ground or have any power in it, it's hard to trace this wire I was wondering if anyone had a wire diagram for the courtesy lights or could just point me in the direction to where the wire starts on the fuse box, thanks!
Offline ehjorten
Re: Courtesy and dome light problems
« Reply #1 on: July 26, 2017, 04:33:01 pm »
Power goes to the dome lamp through an orange wire coming off of the headlamp switch.  The door jamb switches make a ground path for the dome lamp.  This should be a white wire.  Check to see that you are getting 12 volts to your dome lamp first.  That will tell you if it is a problem with the power or ground side of the circuit.
-Erik-
« Reply #2 on: July 26, 2017, 04:42:45 pm »
okay, yeah the dome light is getting 12v so it is a ground problem, following that wire is a real pain, that being said what do you suggest I do?
« Reply #3 on: July 26, 2017, 05:24:09 pm »
Remove the left sill plate and inspect the wire pair passing underneath.  It's common for the wires to corrode and sever if their insulation has been compromised by a retaining screw or pinching by the sill plate.  Check the inline connector in the left B pillar for evidence of oxidation.  While you're there, momentarily ground the white wire at the inline connector to see if the dome lamp illuminates.
« Reply #4 on: July 26, 2017, 08:33:02 pm »
I found a corroded wire! Thank you!
« Reply #5 on: July 26, 2017, 10:19:53 pm »
8)
