Author Topic: Odd ball tires  (Read 7725 times)
Offline Gusgusa1
  • Gasket
Odd ball tires
« on: July 27, 2017, 05:04:13 pm »
I came across 2 33" duratracs and 2 33" big mud terrains. I want to put them on the truck until budget allows new shoes all around.
Considering all 4 are aprox 50% which should be front and which rear ?  Thanks for the help.
2002 gmc 1500hd 6.0 4x4
1987 gmc Sierra classic 1500 350ss 4x4
1986 silverado 350 4x4
1984 scottsdale 305 quad jet 4x4 4spd manual
1982 camaro z28 350 w vortec heads spool
Offline hwh
Re: Odd ball tires
« Reply #1 on: July 27, 2017, 05:49:35 pm »
Duratracs front. Mud tires in back.
Offline Da67goatman
  • Burban
Re: Odd ball tires
« Reply #2 on: July 27, 2017, 06:10:34 pm »
Assuming your referring to BFG Mud Terrains and Goodyear Duratracs:
Duratracs are softer and tend to have a lot of tread squirm and sidewall flex so putting them up front will make the truck feel wishy-washy and disconnected from the road, therefore I recommend the BFG up front.
<Pitcrew>
Offline Gusgusa1
  • Gasket
Re: Odd ball tires
« Reply #3 on: July 28, 2017, 05:55:52 am »
Just wondering what the reasoning. I think it would be looks.
Re: Odd ball tires
« Reply #4 on: July 28, 2017, 07:43:02 am »
you want the tires with better traction in the rear even in a FWD car. the reason being if youre taking a turn the rear has a higher chance of sliding out if it looses traction more than the front.
Offline Gusgusa1
  • Gasket
Re: Odd ball tires
« Reply #5 on: July 28, 2017, 08:41:17 am »
Irish
So which do you figure is the better traction? Duras are wider contact with side wall bite but mud terrains are more aggressive
Re: Odd ball tires
« Reply #6 on: July 28, 2017, 09:21:32 am »
dont know cant answer truthfully. you can however do a google search for those tires and the "traction rating" but that really only covers straight movement. the side pattern of the tires are the turning traction of the tire. they both are "all season" tires and neither one is strictly a street tire.
if it was me i would just put the tires with the most tread on the rear.
Offline Gusgusa1
  • Gasket
Re: Odd ball tires
« Reply #7 on: July 28, 2017, 10:13:58 am »
Sounds like 2 votes for Dura in front. Bfg mt in rear.
Offline Gusgusa1
  • Gasket
Re: Odd ball tires
« Reply #8 on: August 03, 2017, 02:58:46 pm »
They are both 50% ish
Offline teamcurtis
  • dangerous mechanic
Re: Odd ball tires
« Reply #9 on: August 03, 2017, 03:10:59 pm »
if they are all 50% your probably just splitting hairs.
go with what you think looks better
1978 C10 Short Bed
350 smogged for CA
Offline Gusgusa1
  • Gasket
Re: Odd ball tires
« Reply #10 on: August 03, 2017, 05:58:25 pm »
Better than 50 no more than 80. Still good tires. Looks mt up front function dura up front due to side bite. Oh well who says can't s itch them around for a mud bog 😂
